Longer Rods, Higher CR?
Old Oct 4, 2003 | 02:32 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
If you was using a 5.7 rod and switched to a 6.0 rod, why wouldnt that raise your CR?
Old Oct 4, 2003 | 05:09 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Because you get pistons with the coresponding change in compression height, so that the piston ends up in the same place.
Old Oct 4, 2003 | 05:37 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
he's correct. you don't just switch rods without switching pistons. if you didn't, you'd have a piston meeting the cylinder head. 6 inch rods do allow you to run a bit higher compression than the 5.7 rod without detonation though.
Old Oct 4, 2003 | 09:21 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Thanks guys. Reason i asked is b/c i just read a post about a guy if he should use 5.7 or 6.0 rods and thy said nothing about using a different set of pistons than the ones he was going to use.
Old Oct 4, 2003 | 09:26 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Is that your stock times for the sonoma?
Old Oct 5, 2003 | 01:03 PM
zippy's Avatar
Engine: 5.3L
nope, when i first got it, it was only good for 16.3. planning to break into the 14's before winter. i've also pulled off a 2.137 60' with it.
evilstuie
Sep 24, 2015 12:04 AM
WhteRbt
Sep 21, 2015 09:48 AM
BWilcox
Sep 20, 2015 12:19 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
