How can I test out my Fuel Level Sending Unit?
Old Oct 4, 2003 | 07:10 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
ok heres the problem....my fuel level sending unit went out on my car and I just bought a used one from third gen resource and I would like to test the sending unit out before I go to the trouble of putting it in and then finding out it does'nt work.
So Does anybody know how to test one of these out?
Thanks.
Old Oct 4, 2003 | 07:40 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Get a good voltmeter that can test resistance. Locate the signal wire from the sender, set your voltmeter to test resistance, attach the positive lead to the signal wire, and ground the negative lead to the sending unit, then move the sender arm. If it's good, the resistance on the voltmeter should change as you move the arm. Kind of hard to explain without a pic, but I hope you get the idea.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Irocohio
Aug 12, 2015 08:03 AM
