manifold
Old Nov 28, 2000 | 02:31 PM
rdayz28's Avatar
manifold
i am thinking about switching from performer intake to performer rpm on a305 600cfm carb elgin cam 220intake 220exhaust .429lift intake and exhaust going to put on a set of 305 torqer heads also have heddman shorty headers and y pipe what will the rpm do that the performer doesnt?
Old Nov 28, 2000 | 02:39 PM
R.O.B.'s Avatar
The RPM will flow more. It is designed to work in the 1500-6500 rpm range, while the performer is designed to work in the idle-5500 rpm range. Basically, what rpm range is the rest of your package set up for? The heads I believe are only good to 5000 rpm. Look at the cam manafacture's spec card for its operating range. It does no good not to properly match your parts.
Rob
'86 TA 305 TPI
db057
Jan 10, 2020 08:55 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
86CamaroDan
Sep 29, 2015 10:08 PM
