New distributor install / timing problem
Old Nov 28, 2000 | 07:14 PM
Alan84TA's Avatar
Getting ready to installing the distributor in my recently rebuilt engine and noticed it doesn't seem to have the same timing tab on the timing cover. My old one was a tube with what looked like a saw blade. The timing cover the shop put on has a small triangle but is farther to the right than the orignal and looks almost smashed out of shape. Not sure to trust it or not, or if it is even a timing tab.. It was a 305 but now has a 400 crank so the damper is biger and I don't think the old cover would have worked anyway... not sure what I should do at this point.
Old Nov 28, 2000 | 08:29 PM
ede's Avatar
ede
if you have the same timeing cover and it matches the damper you should be ok. the distributor wouldn't matter. i read it twice and was never clear what you have, or what you changed. you can always find TDC and check the damper and the timing mark.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 28, 2000 | 09:57 PM
Alan84TA's Avatar
Its currently a 335... I do not have the 305 cover anymore... this isn't a good picture but does this look like a timing tab? like I said its bent bad if it is...
[This message has been edited by Alan84TA (edited November 28, 2000).]
Old Nov 28, 2000 | 10:09 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
That looks like they cut off the timing tab.
You could probably just use an aftermarket tab (Mr. gasket, etc.) that bolts to the timing cover.
The dist. drops in as normal.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited November 28, 2000).]
Old Nov 28, 2000 | 10:15 PM
Alan84TA's Avatar
I was able to bend the point on the tab back down to where it looks normal... Its pretty week and I was affrade it would break off, but it didn't.. Do I need to grease the distributor gear or shaft before installing it? Chiltons doesn't say to but want to make sure..
Old Nov 28, 2000 | 11:02 PM
Bort62's Avatar
yeah grease the Gear Good
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
stalkier
Aug 7, 2015 04:49 AM
