Could use some serions help with rear end.......
Old Nov 27, 2000 | 06:27 PM
irocbsa's Avatar
Ok, y'all, for those who have been following the previous thread you know the deal. Anyway, I talked to the dealer and they said that the whole thing is trashed: gear, carrier, axles, everything. They quoted me 1600 dollars. I really need to know my options here. Should I just find one at the yard and stuff it with good parts or what. I need to know some LESS EXPENSIVE options. Could really use some help here...........
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat,
Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
Old Nov 27, 2000 | 06:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yah, you should be able to find a rear end in the junkyard or the classifieds for $300 or so.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 27, 2000 | 06:40 PM
irocbsa's Avatar
what kinda goodies do you suggest I stuff it with, I don't want to rely on an off the shelf junkyard mutt. I think that the power out of the motor helped tear up the last one. Does anybody sell a complete kit for this kind of thing. I have no idea about diffs.
bsa
Old Nov 27, 2000 | 06:41 PM
Kevin91Z's Avatar
See the "Building a Better 10-bolt" article in the tech section here.
Old Nov 29, 2000 | 08:24 AM
Pat Hall's Avatar
I'd suggest a Zexel-Torsen differential and an aluminum rearend cover/support brace. Both of which are in the article Kevin mentioned. The support brace helps prevent the ring gear from deflecting from the pinion due to housing flex. According to popular legend, this is the reason these rearends fail most of the time supposedly.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
