simple pulley q
Old Oct 6, 2003 | 07:12 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
simple pulley q
If one of your pulleys squeals/whines while the cars running whats that a sign of and how do you fix it.
Old Oct 6, 2003 | 08:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A slipping belt.
Look for shine between the ribs of the belt and on the top of the ribs on the pulleys. That's a sign of the small "vee's" on the belt being worn out. Or, possibly wear of the pulley(s) itself.
The tensioner should be putting the proper force on the belt as well. A worn belt or tensioner spring can contribute to that problem.
Old Oct 7, 2003 | 06:21 AM
ede's Avatar
ede
or a bad bearing on the same shaft the pulley rides on
Pac J
May 17, 2020 10:44 AM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
