Fuel pressure w/ speed demon 750 dp
Old Oct 7, 2003 | 07:36 AM
Momar's Avatar
Well, I have been been buying some goodies the last couple of days. I am getting the carb mentioned above, and also ordered a carter fuel pump. I was thinking that the pump was 7psi, but after I ordered I realized it was 8. Will this be to high? If so I have a regulator, but will it hurt a mechanical pump to regulate it down? The only carb I really have experience w/ is my cc quadrajet so I dont really know. I put a t56 in and so I really wanted a dp carb. What should I do w/ the fp. Do I need to order a different pump or can I make this work? I have run a best of 9.410 in the 1/8 mile, but it feels like I am running out of fuel up high w/ my current pump(still using quad by the way). I also have a set of sportsman II's that I have started porting and will finnish soon if I could get enough free time.
Ben
Old Oct 7, 2003 | 10:53 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
From http://www.barrygrant.com/demon/default.aspx?page=28
"The fuel pressure should be between 6 and 8 psi. Most carburetors should be set to operate at 6 psi."
A regulator won't hurt the mechanical pump operation at all, assuming the reg itself can handle the fuel flow.
Old Oct 7, 2003 | 03:29 PM
Momar's Avatar
Well, I dont know what brand it is, but I believe that the regulator I have is pretty cheap. I guess I can try it and see if it works. Are you just saying that it may not be able to flow enough fuel or what?
Ben
Old Oct 7, 2003 | 06:06 PM
five7kid's Avatar
If the reg flow passages are small, it may not flow what the carb needs even when wide open.
I'd try the carb & pump by themselves first. The BG info seems to support 8 psi.
Old Oct 7, 2003 | 08:22 PM
Momar's Avatar
Sounds like a plan. When I get this stuff on, I will be back for some tuning advice I am sure.
Ben
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Fireslash
Apr 11, 2016 06:43 PM
meeklay812
Oct 1, 2015 03:46 PM
angel2794
Sep 8, 2015 06:22 PM
