Backfiring... is it ok?
Old Oct 7, 2003 | 11:37 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
when i took off my cats, i noticed that the car would backfire when i rev it real high, or if im cruising and i let off the gas... i can hear it backfire in the exhaust while im rolling with my foot off the gas... is that ok? or is there a problem? thanks guys
Old Oct 8, 2003 | 05:26 AM
ede's Avatar
ede
in the exhaust a backfire would be unburnt fuel being lit off by the cat or some other heat source. i'd make sure i had a good tune up, but it isn't an uncommon occurance to have exhaust pop like that
Old Oct 9, 2003 | 09:49 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I think your talking about backpressue. Does is not it when you first crank it up in the morning and then starts doing it after your car has warmed up? If so thats backpressure.
Old Oct 9, 2003 | 09:52 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
thats just what some motors sound like when they arnt muffled...... downshift and you're hear it alot mroe.
Old Oct 9, 2003 | 10:14 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
even with a full exhaust with my chambered mufflers when i rev it up real fast i hear that pop pop pop of the back fire i love it it sounds sooooo cool its just because your car is dumping gobs of fuel into the cylinders and some of it is entering the exhaust still unburnt so it explodes inside the exhaust.....as long as it is this normal sort of back fire youre not hurting anything.
Old Oct 10, 2003 | 07:28 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
your so right, my car had a burnt wires and i downshifted ne day and i was like WTF this thing gets loud.
Old Oct 11, 2003 | 05:31 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
hahaha
I knew a person who had a firebird formula, 305, and he wanted it to be louder without investing in a better exhaust system so he drilled holes in the cat (ha?) and everytime he left the parking lot it would tick and sound like the thing just needed to be shot n put out of its misery.
