hot starts are a *****!!!!
Old Nov 29, 2000 | 09:17 PM
CamaroZ_85's Avatar
well the subject pretty much says it...i have to crank and crank when i start the motor hot. give it a little gas...crank some more...i get the best results if i press it once and hold the petal to the floor to start it. but i hate doing that because it usually revvs the crap out of the motor when its first starting and i hate to do that to oil starved bearings. when it does start, it runs like crap and i usually have to gas it up a bit to get it normal. it's a carbed motor, edelbrock 600cfm and a regular old vac advance distributor. also dont have an egr. new mech fuel pump...clean filter...cant think of much else, what do you guys think?
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Old Nov 29, 2000 | 10:39 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Does it crank really slowly when hot? If so, the first thing I would look at is backing off the timing. If you have it too far advanced, it could cause this very problem.
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Nov 29, 2000 | 11:55 PM
CamaroZ_85's Avatar
nah it doesnt crank slow...i dont think the timing is advanced too far either
Old Nov 30, 2000 | 07:37 PM
CamaroZ_85's Avatar
btt
Old Nov 30, 2000 | 10:35 PM
john72ss's Avatar
had this same problem with my older car with holley 650..... when i shut off the car.... gas would still be filling in the carb.. i could see the vapors.... check the float sight holes... it might be set too high. gas should just trickle out when level!!... hope this might help!!
72 ss camaro... 350hp 350 with super t-10 holley 650 accel dist/ msd 6al and wires
[This message has been edited by john72ss (edited November 30, 2000).]
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
