Cam suggestions for a near stock LG4?
Old Nov 9, 2000 | 10:59 AM
Smasher's Avatar
I'd like some suggestions on a cam since I've never paid attention to anything less than a 350(except for imports). What would be considered a radical cam for a 305?
What cam would you suggest for the following combination:
1 5/8 headers
Performer 600cfm carb
Performer intake
I don't really want to put heads or anything else on since I'm trying to build another engine on the side.
Ryan- 1985 Monte Carlo CL
Yes, I'm bitter towards the SS
Tealnet Your #1 Automotive Resource on the 'Net
http://scaryfast.homestead.com/ <--- My homepage
Old Nov 10, 2000 | 01:55 AM
Teddy Z's Avatar
I threw a 204/214 @0.05 (.420/.442 lift) in my LG4 and now it seems like a V8 My car is basically otherwise stock except for headers, catback, accel supercoil, and a crane cams adj. advance curve kit.
Old Nov 10, 2000 | 03:24 PM
Smasher's Avatar
TTT
Old Nov 11, 2000 | 07:58 AM
Biochem's Avatar
Car: 2002 SOM z28
A radical cam for a 305 would be Comp cams 262 grind (218/224 with about .470 lift). Carb engines can get away with more duration then FI can IMO, so going with either a tighter LSA or longer duration wouldn't be a bad thing. It depends on what you want from this engine... low end grunt or top end screamer. I would think with a longer duration cam, you would really want a converter to go with it... especially in a heavier car. You really can't go wrong with a short duration/ high lift cam for midrange power (ie-street car). While you may not have to invest in a new torque converter, you may have to get better springs and porting really helps.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Old Nov 11, 2000 | 08:08 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Read my sig below. I like my comp cams XE262H. Check out my web site for WAV files of the idle quality, zero to 60, and Hooker Aerochamber. This cam needs a torque converter, or a 5-speed, however. I'm turning 14 flat at nearly 101 MPH with my 305 and this cam. http://www.isthq.com/~dan/fcar.html
Daniel Burk
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Old Dec 1, 2000 | 02:01 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
you might consider the eldebrock performer cam (or a similar grind) as it is designed to work with the manifold and carb you listed...
zroc
sweet_87_iroc
Sep 25, 2015 10:01 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
sreZ28
Aug 14, 2015 07:48 PM
drathaar907
Aug 6, 2015 04:20 PM
