smog pump removal
Old Nov 30, 2000 | 12:39 PM
chris1roc's Avatar
smog pump removal
I was told that if I take the smog pump off that it will throw my motor out of balance. Is this true? Does it make a difference taking it off? It's easy to take it off right?
_____________________________________________
88 iroc
305 tpi
Old Nov 30, 2000 | 12:47 PM
bleak's Avatar
no, yes, and yes.
Old Nov 30, 2000 | 01:12 PM
Dana92RS's Avatar
If you do remove the smog pump, there's a pulley that you can install in it's place so that you can still use the OEM serpantine belt and routing, instead of re-routing it as described in the tech article. I ordered one and it's supposed to be here tomorrow. If I get it on this weekend I'll try to get some pics. I posted the part number in another thread on this board, do a search for posts made by me or ones titled "smog pump delete pulley".
Old Dec 1, 2000 | 12:41 PM
jrr's Avatar
jrr
In the bad ol' days of the 1970's, when low-compression smoggers roamed the streets wheezing through pellet-bed cat converters (God, I sound OLD) we simply got smaller belts. There is a way to look at a belt part number to find out how long is. Then you can make a good guess at what the new belt ought to be without the smog pump. If the shop or parts store has cool people behind the counter, they'll let you try on belts in the parking lot until one fits right.
Old Dec 1, 2000 | 03:01 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Take a string and wrap it around all the rest of the pullies and then measure it. Then tell the guy at the parts counter you need a 6 rib belt x inches long.
James
If the women don't find you handsome they should at least find you handy
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
Old Dec 1, 2000 | 03:46 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
THere is a tech article on this (does anyone ever visit the tech section?)
968k6 is the belt, routing is described in the tech section
ive taken it to 6500 rpm, no problems
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
