engine dies when hooking tach
Old Oct 13, 2003 | 05:15 PM
camaroracer1's Avatar
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Transmission: TH-350
Axle/Gears: 12bolt/4:10
I have a 88 iroc, I have ditched the ecm and running a 350ci with
a hei distributor with the vaccum advance. The coil is in the distributor. The white wire on the coil is supposed to be the tach hookup wire, but when I hookup the tach to the white wire the car won't start. When I start the car and try hookup the tach the car dies. The tach i'm using is a Mallory with the built in rev limiter and shift light. The tach does work on my other car. WTF is going on.
1988 Iroc-Z
350ci
700r-4 2500 stall
"don't mind the lope, they all sound like that!"
Old Oct 13, 2003 | 05:17 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
are you hooking the tach up to the terminal right next to the big pink/red power wire?
Old Oct 13, 2003 | 05:36 PM
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Maybe,but the white wire coming out of the coil isn't on any terminals its just hanging out. But just to make sure i'm going to take a look at it right now.
Old Oct 13, 2003 | 06:32 PM
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Okay I looked at the coil in the cap and there are 6 wires coming out. The white wire is the only one not used, so what's going on.
Anyone?
Old Oct 13, 2003 | 06:37 PM
Dave Y's Avatar
Engine: 4.3L V6
can you post a pic?
eightsixseven
Dec 16, 2024 01:50 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
stalkier
Aug 7, 2015 04:49 AM
