Skipping at around 3000rpm
Old Dec 2, 2000 | 01:51 PM
Grover86's Avatar
Okay I recently replaced my aluminum heads for stock head and changed out the roller cam for something close to stock for a 350 to sell the car. The car runs fine (is a lot slower) except for a skip that is around 3 grand. I changes the wires, plugs, cap and rotor button. That didn't help. The car still has the MSD ignition, and advance kit. What could be causing this problem.
Old Dec 2, 2000 | 10:41 PM
Vader's Avatar
Grover,
If you're sure the problem is not fuel related, you can also check the pickup coil and reluctor in the distributor. The ignition coil itself could be failing, but as long as you're in the distributor, you might as well check everything.
It's possible you are getting a little lean at higher RPMs and getting some lean backfire that will feel like an ignition miss at times.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 3, 2000 | 04:19 PM
Grover86's Avatar
Thanks, I'll give the pickupcoil a shot. The ignition coil MSD blaster 3 and not more than six months old. It is probably still good, but it could be bad. Will check in the fuel idea to. Thanks for the help.
Zane Story
Oct 8, 2015 12:40 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Mike86SC
Car Audio
Oct 22, 2002 05:30 PM
shaocaholica
Nov 25, 2001 08:50 PM
87 Firebird
Car Audio
Nov 6, 2000 04:27 PM
