installing roller rockers..a few ques..
Old Dec 3, 2000 | 03:05 PM
UnderDogRS's Avatar
i have a set of roller rockers and want to install them in my 305. but i have a few questions(never done something like this before). do i just remove the old stamped ones and install the new ones a tq then down, they have the 12pt adj tops.
and would i be able to put them in a diffrent engine or heads in the next few mos.
tia,
RS
(A.K.A FireBird88)
AOL SN: Zander0710
1992 Camaro RS 25th anniversary edition Adopted Feb,14 2000
Mods:
14x3 Open element w/ K&N filter, MSD 6a, MSD GM blaster Coil ,MSD 8.5 SC wires, AFPR,Fuel Pressure gauge(60Psi max), 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
Old Dec 3, 2000 | 05:46 PM
ede's Avatar
ede
rockers on a SBC don't torque down. you have to adjust the rocker to get the correct amount of lifter preload. with the valves closed tighten the rocker nut untill the push rod stops spining (spin it while you tighten) then 1/2 turn more should be good. if your rocker nuts have a set screw tighten it up after settign the lifter preload.
-=ICON MOTORSPORTS=-
1st & 3rd
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
red90IROCls1
Aug 25, 2015 06:56 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
