What involves a swap from 305 to 400 tpi?
Old Dec 2, 2000 | 03:35 PM
TransAm86's Avatar
If I start out with a 305 tpi, do I only need to change the block?
what else needs to be changed?
heads?
injectors?
sensors?
Old Dec 2, 2000 | 06:27 PM
Tas's Avatar
Tas
305 TPI intake setup will choke the crap out of a 400 unless you want a torkie engine win minimal HP. you would want larger TPI parts, bigger injectors, asjustable fuel pressure regulator, chip. A good exaust system would help. SLP 1-3/4 headers.
-Tas
'89 Formula WS-6
[soon to be Performace Red =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
ICQ 82881207
Old Dec 2, 2000 | 06:54 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
At the bare minimum to get it running, nothing. However, for it to run halfway decent you need bigger injectors and a 350 (or custom) chip.
That's just to get you by though...
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Dec 2, 2000 | 07:11 PM
Tas's Avatar
Tas
that's why I said "want" and not "need".
Old Dec 4, 2000 | 01:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 305 heads choke a 305. You could use them on a 350, but by the time you got it to run right, you could have started with proper heads and done it cheaper and sooner.
Since you asked about just changing the block, 305's & 350's have different harmonic balancers and knock sensors. However, 305-type 19 lb injectors will work with a 350 if the fuel pressure is bumped up.
But, again, if you just want it to run...
Vintageracer
Jan 10, 2020 05:33 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
lakeffect2
Aug 23, 2015 08:44 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
