350 casting info plz
Old Dec 4, 2000 | 10:07 PM
UnderDogRS's Avatar
i got a 350 from a junkyard today. it was supposed to be a roller block(87+) but i cant
decide what it is. it had flat lifters, and 1pc rear seal. the numbers on the back of the block are 10054727.
TIA,
RS
(A.K.A FireBird88)
AOL SN: Zander0710
1992 Camaro RS 25th anniversary edition Adopted Feb,14 2000
Mods:
14x3 Open element w/ K&N filter, MSD 6a, MSD GM blaster Coil ,MSD 8.5 SC wires, AFPR,Fuel Pressure gauge(60Psi max), 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
Old Dec 4, 2000 | 10:26 PM
ede's Avatar
ede
got to www.mortec.com
-=ICON MOTORSPORTS=-
1st & 3rd
[This message has been edited by ede (edited December 04, 2000).]
Old Dec 4, 2000 | 11:16 PM
UnderDogRS's Avatar
10054727...350...86-up...2 or 4...one piece rear seal, some "Made in Canada"
so i guess this is not a roller block. oh well.
thanks,
RS
Old Dec 4, 2000 | 11:50 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Does it have the threaded bosses for the lifter "spyder" and a machined surface along the lifter valley?? (on both sides where the lifters poke through)
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Dec 5, 2000 | 12:11 AM
UnderDogRS's Avatar
EB,like the sig!!
[This message has been edited by UnderDogRS (edited December 04, 2000).]
Old Dec 5, 2000 | 01:56 AM
Pat Hall's Avatar
Originally posted by UnderDogRS:
EB,like the sig!!
I can't guarantee this statement is 100% accurate, but from what I hear, all one piece rear seal blocks are supposed to have the provisions for a factory roller cam setup. You probably got a truck 350 block. I heard a lot of those came with standard flat tappet cams, but like I said, it should have the provisions for a roller cam. The bosses may have to be drilled and tapped if they're not already, and you'll need to buy the cam thrust plate that bolts to the front of your block from GM. You can probably find all the roller parts you need pretty cheap in the classifieds here. A lot of guys have extra parts just laying around for them.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Dec 5, 2000 | 07:40 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
UnderDogRS:
Thanks.
Pat Hall:
Yep, I have one of those 86 truck blocks that is a roller block thats not roller. Mine is drilled, tapped, and machined everywhere it needs to be. Just no roller cam.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
inferno15
Aug 29, 2015 01:48 AM
Eric-86sc
Aug 24, 2015 09:01 PM
gta power
Aug 13, 2015 06:15 AM
