crankshaft position sensor?
Which cars have the sensor? i have a 1990 350tpi and all the car does is crank over. Already checked the ign module, coil, plugs. what could the prob be?!
Doesn't have one. The distributor sends reference pulses out to the computer when the engine cranks.
Might want to try starting fluid now to see if its a fuel problem. Anything done to the car recently? Has it been sitting?
its been sittin for bout 2 weeks...well i put another set of plugs in and it was running really really rich, so i pulled the new plugs out and i guess it keeps fouling plugs, any way to fix it!?
all you need is spark, fuel, and compression. you have spark right? did you check it with a spark checker or an old plug, big differance. you may not be rich at all but have a spark problem. check the FP, injectors, and anything else related to fuel system. maybe stuck or dirty injector
Hotrodboba400
Dec 10, 2019 07:07 PM
