Why do I keep eating up ignition rotors?
Old Dec 4, 2000 | 10:40 PM
nelliesIroc's Avatar
I have a 305 tpi and over the summer I put on an accel cap/rotor kit and a accell coil it worked great until a month ago I was driving and the car just died on me so turns out the rotor was bad it wasn't scorched or anything so i replaced it and yesterday the same thing happened rotor looked fine but replaced it and car started right up. So I put the original coil and a new cap on and the car is running like crap now it's surging and idling like crap too. I'm totally stumped. Does anybody have any ideas? I need all the help I can get.
Old Dec 5, 2000 | 01:10 PM
Mark 89Formula's Avatar
Take a close look at your other ignition components for problems. They can cause premature wear on the cap and rotor. In my case the magnetic pole piece and pickup coil in the distributor were so corroded it was a real testament to the HEI and Jacobs box that the car ran at all.
Old Dec 5, 2000 | 05:46 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Nellies, I would first suggest you inspect your wires (including checking resistance). I would then look to all the distributor components. In particular inspect your carbon brush and the ground strap located under the coil.
"The people always have some champion whom they set over them and nurse into greatness... This and no other is the root from which a tyrant springs; when he first appears he is a protector.
-Plato
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
loud91rs
Oct 5, 2015 10:05 PM
Racerx974
Sep 19, 2015 10:16 AM
