Headers and Spark Plug Wires, OUCH!
Old Dec 4, 2000 | 02:56 AM
nesluopetan's Avatar
Ive got an 82 Z28 and I just stuck on some edelbrock TES headers, and now im not kidding you, on the #1 spark plug, the wire goes DIRECTLY through the headers to get on the spark plug, and it melted right through the wires!! what the heck can I do to fix this, there is absolutely no other way to route it, do they make special wires for my car? i have not found them anywhere, its just on the #1 plug.. if this helps my engine is the 305.. please help with ANYTHING you can.. thanks..
Old Dec 4, 2000 | 07:59 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
With headers sometimes you need to get a longer wire and route it differently.
If this isn't an option, you can use a shorter plug (accel makes some "header" plugs) or you can get some "DEI Wire Sheaths" from Summit. (Pg.115) These will cover your plug wires and protect them from the headers.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Dec 4, 2000 | 02:58 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Are you using 90 degree boots? They work fine on mine.
Mark Lock
- 86 IROC-Z - Torn down for 383/SuperRam T56 setup
- -= IROC Online =- - The site dedicated to the IROC-Z
Old Dec 4, 2000 | 03:25 PM
Yeah I am, it is the boot that is hitting my headers, there is absolutely no way to get around them without hitting them, 90 degree boot, etc, the way its setup is it goes directly through the headers to connect to the spark plug, it is unreal, i dont know what to do, i could get this heat tape, but yo know as well as me that it will melt that, knowing how hot headers get.
Old Dec 4, 2000 | 04:55 PM
ede's Avatar
ede
i use the nomex (or whatever it is) wire insulation, doesn't burn no matter what.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Dec 4, 2000 | 06:25 PM
SeanSullivan's Avatar
I Had that problem as well, but on the other side. I'm using a heat sleeve, and a straight boot. Am using Hooker shorty headers tho. Might be a difference in the setup, but that would be difficult to believe.
Old Dec 4, 2000 | 07:39 PM
Mo's Avatar
Mo
Sean...
How do you like those headers and what kinda car/engine do you have them on?
I am planning on getting the shorties w/ air
Mo
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
Old Dec 4, 2000 | 08:04 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
I've got the TES headers on mine, and I know what you are talking about. Mine isn't quite as bad as yours, but I did end up purchasing a set of the Accel shorty spark plugs. They are roughly 5/8 inch shorter than standard plugs, and with the 90 degree boots mine clear the headers.
Old Dec 4, 2000 | 10:36 PM
ede's Avatar
ede
i had tes on my 350 iroc. i had to use accel shorty plugs on it with moroso blue max wires with 90* boots. no big problems, but i did have insulation on the wires.
1st & 3rd
Old Dec 4, 2000 | 10:53 PM
Yeah, but my wire is okay, its my boot that is melting.. and the boot is a 90 degree boot, it has no where to go but on the headers, know what i mean, let mek now, and where do i get the header sleeves?
Old Dec 5, 2000 | 09:25 AM
Mo,
I really like them, I don't, however, have the air system tho. Hooker part number is 2460, I think. They weren't very expensive either, $165.00 I think. Mine were on the 305, but am in the process of swapping a 350 this week. They're suppose to fit either engine. We'll see. The 350 I got is a 77 model engine, doubt that there's any difference in the blocks tho.
Old Dec 6, 2000 | 09:01 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Plain and simple, you're doing something wrong. Having had edelbrock headers and never a single problem with burned wires 9and i didn't use anything fancy either, and even accel 8.8s with fat boots were fine) i can assure you there is no trick to it. I also never used short plugs, standard ACs were fine.
Personally, i liked the clean look of stock and ran the wires under the headers from behind the block using the factory wire looms on the DS. I do recall that i test fit some wires running them over the valve cover, but decided against it since they would just be in the way most of the time.
In short, like Nike says, just do it. They do fit. Thousands of thirdgen owners can't be wrong.
...ed
Old Dec 6, 2000 | 09:22 AM
airbrushguy's Avatar
Try ceramic boots, I had them in the past on hot rods. I think Champion still makes some
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
