Chea[est Way 2 500 hp
Old Oct 18, 2003 | 06:18 PM
tyty49's Avatar
Car: 91 Maro & 97 Ram & 05 Roadstar
I'm looking to make 475-500 horsepower not on nitrious. Maybe some of you are making big numbers? Let's see what you've got.
Old Oct 18, 2003 | 08:56 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Without juice or a built BB your not going to see 500hp cheap or easy. If you dont want N20 then your only other option is a super charger but the one that will do it is 3k alone not including the dual carbs that feed it or the at least 400 SBC to ride under the supercharger.
Old Oct 18, 2003 | 11:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
cubic inches
Old Oct 19, 2003 | 12:40 AM
FlamedROC's Avatar
Car: 1989 IROC-Z
My SIG says it all!! but when u want those numbers you have to spend lot of money...no cheap way around it unless the parts are used or u have a sponser that helps out.
Old Oct 19, 2003 | 12:46 AM
EvilCartman's Avatar
Car: '82 Z28
What sig?
I'm spending right around 5,250 bucks from carb to pan including machine work for a 355 that'll be pushing 475 to 500 hp. You can do it cheaper though if you get parts that work well together or find some good deals. About the only thing I'm reusing in my setup is the block, just about everything else I've bought new.
Old Oct 19, 2003 | 12:48 AM
FlamedROC's Avatar
Car: 1989 IROC-Z
Its there now..lol forgot to hit the sig button..
db057
Apr 28, 2019 07:45 AM
L98GTA87
Oct 19, 2015 10:43 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
pacoelrapido
Sep 11, 2015 02:41 PM
