Cat. Conv. Question
Old Dec 6, 2000 | 11:07 AM
craig90formula's Avatar
Cat. Conv. Question
Tried on the exhasut board and got no response, so I'll try here. I need to replace the cats on my dual cat setup on a stock 305 TPI. I was looking at 2 options - replace both, or convert to a single high flow cat. How much diff. will a single high flow cat vs. the dual cat setups make? The only other mod is I have a hooker aerochamber muffler (which is on its way out too!).
Thanks!
Old Dec 6, 2000 | 11:25 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Can't help with the effectiveness, but I think you'll need a new Y-pipe as well, or more modifications to the existing one...
Could get the cost back up to buying two cats...
Old Dec 6, 2000 | 11:48 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Whats it look like under a f-body with 2 cats?? Are they beside each other?? On top of eath other?? Does each side of the engine run into a cat?? Or does it go into a y pipe then into the 2 cats and them back to the muffler?? You could just put a piece of pipe in, instead of the cat.
Old Dec 6, 2000 | 02:52 PM
Yeah, I know I'd need a new Y-pipe. Just looking at options.
Godti - Its two cats side by side, then a Y into a single 3" intermediate pipe. Unfortunately I can't just run pipe, gotta pass emissions on a treadmill here in MD.
Old Dec 6, 2000 | 06:49 PM
Mo's Avatar
Mo
why not dual hi flo cats? For about $100 a piece, a new y pipe will probably be almost 100.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
