TPI Inline pump recommendation?
Old Oct 20, 2003 | 09:57 AM
Hoss50's Avatar
Car: 1985 K5 Blazer
Engine: 350 crate w/TPI MAF
Transmission: 700R4/NP208
I need a recommendation for a TPI fuel pump. I am swapping in TPI and I am looking for a good fuel pump for a good price. Anyone recommend one? I don't need super high GPH, just enough to supply a stockish 350.
I have seen the Holley for $160 and a Walbro for $120ish. I was looking for something a little cheaper if possible, but I want a pump that will last. I was wondering if anyone knew of an OE application that could work. Thanks
Harley
Old Oct 20, 2003 | 12:18 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Carter makes an OEM pump that runs about $70. You can get it at just about any parts store. I'm currently using that one in my TPI, and It works great.
Old Oct 20, 2003 | 12:31 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Do you mean a inline as out of tank? as a 2nd pump? Or do you plan to remove your intake and go extranal only?
Id just get a walbro and drop it in your tank. Just incase you deside to do some mods down the road.
its a good pump.
I pulled my intake pump and have a Extranal T-Rex pump.
Old Oct 20, 2003 | 01:03 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
If your gonna keep the intank pump you mid as well get a good one. Most of us on the boards know how much of a PITA it is to install a fuel pump on our cars.
I was going to get a walbro pump myself and stick it in the tank but I dont need that much pressure. I am running carb so I plan on getting a carbed car tank pickup and running a holley blue electric pump in-line somewhere.
Old Oct 20, 2003 | 11:12 PM
Hoss50's Avatar
Car: 1985 K5 Blazer
Actually I don't have an intank pump. I am swapping TPI into an 85 GMC Jimmy 4x4. I am looking for a stand alone external pump to mount near the fuel tank. Thanks.
Is that Carter OE pump an external?
Old Oct 21, 2003 | 06:20 PM
MarkS's Avatar
I got the accel pump from summit. part # ACC-74701 I've been really happy with it since my TPI swap. Some people don't like external fuel pumps because of the noise they make but I can barely hear this one except for when I go to start the car. Of course my exhaust could have something to do with that. Its $145 so its not cheap, but a TPI swap isn't cheap.
Old Oct 21, 2003 | 06:41 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
EXTERNAL
http://store.summitracing.com/partde...%2D8F002%2D265
Grant2k
Jul 10, 2018 04:01 PM
NBrehm
Aug 25, 2015 11:49 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
