lopey cam sound in a fuel injection?
Old Dec 3, 2000 | 05:27 PM
Abe91Z28's Avatar
ok, i have a question about making your car have the nice powerful sound of an old lopey muscle car. Is it possible on a TPI engine? (i'm asking this because i think its possible, while my friend who has a 73 monte carlo says that my car cannot because its a TPI) i also was wondering that if i add a cam, what kind of lift and duration do i need to make my 305 sound like that? (if its possible that is.) I'm sorry if this sounds dumb, but i'm fairly new to building up and engine.
-Abe
1991 Z28 305 TPI.
Mods: Hypertech Airfoil, gutted airboxes, K&Ns,polished 91' rims (they turned pink!), and all rear end bushings & tranny mout are energy suspension poly ones now
MORE TO COME: Any suggestions on what to do next? I really want to try and make the 305 run 13s (i've mostly been doing basic repair to the car, but now most of its done i have money to mod!)e-mail me@ abraham_39@hotmail.com
Old Dec 3, 2000 | 07:20 PM
theformula's Avatar
The key to the lopy sound is usually in the lobe separation. A lobe sep of 112 will give a slight lopy sound. 110 and 108 is probably what your looking for. However, I wouldnt go below 112 on a TPI.
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (47psi),MSD6AL,AC delco cold plugs, Bosch O2sensor, homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges
Old Dec 4, 2000 | 01:43 PM
Abe91Z28's Avatar
so, if i got a cam with duration around 112 (and matching heads) would i need to get a custom chip burned or, could i get by with a chip from an aftermarket company like performance resource?
Old Dec 4, 2000 | 06:37 PM
theformula's Avatar
I have no experience with their chips, but I'll have to say you will need a custom chip. Reason being is that you have speed density. Ask them if they will work with you on something. Or you can buy the software for a little over $200 and get way better results.
You should look into other things first. heads and cam will improve power but then your exhaust manifold and intake will become the restriction.
Pick up an SLP stainless steel catback, SLP 1 5/8th headers (group purchase going on now), port your plenum, get a crane afpr. Depending on the heads/cam you get you may need a new intake manifold. Definitely a custom chip. Some gears 3:55s or 3:73s, Drag Radials, bump your timing to 10*BTDC.
92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,K&N, Crane AFPR (47psi),MSD6AL, MSD wires, AC DELCO cap/rotor/plugs, Bosch O2sensor, 3:73s,JET fan switch, Macewen white face gauges, Intellitronix Digital Gauges
[This message has been edited by theformula (edited December 04, 2000).]
Old Dec 7, 2000 | 12:34 PM
Abe91Z28's Avatar
Ok, so, after i get the cam, my headers would be a restriction? i already have the edelbrock TES, but i haven't put them on, because i can't decide on a cat-back&cat to match them up with. I was thinking of the Catco 3' cat with an areochamber catback, but if i go into the group purchase, can i just purchase the cat back and not the headers? also, i was wondering if the TES are considered to be ok for exhaust? Or, did i make a bad choice for headers?
THX
-abe
Old Dec 7, 2000 | 02:35 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its my opinion the SLP headers are better, but since you already bought the Edelbrock headers, use them. If you want the lumpy cam sound, save your money and do everything at once. Buy a 350 roller block, heads, cam, intake manifold, etc, and drop them into your car when you're ready. You can get little stuff now, like exhaust, torque converter, suspension mods, gears, etc, that will transfer over to the new engine.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
86Base
Aug 13, 2015 05:06 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
