air sensor question
Old Oct 21, 2003 | 04:34 PM
tjamison2001's Avatar
Car: 85 Iroc Z28
Engine: 305 V8 TPI
air sensor question
I'm needing to replace my air sensor on a 85 Iroc TPI. The current air sensor in it is a Bosh. Pulled the computer out the other day to swap a chip, and saw that there was a Bosh box bolted to the top of the computer. Did all 85's come factory equipped w/ that, or is it an add on from one of the previous owners? I'd really like to go with a less expensive air sensor @ $160 (replacing the Bosh is almost $600). Where can I find info on removing the box from the computer? Rewiring schematics? Is this possible or am I stuck with the more expensive sensor? Any info on this from you guys would be a great help!!!!! Thanks a bunch in advance!!!!!
Old Oct 23, 2003 | 06:20 AM
ede's Avatar
ede
i think you mean MAF. all tpi had them untill 89 or so (not sure of year) when they went to SD. i think wells is the cheap prefered replacement part maker
Old Oct 24, 2003 | 02:58 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
90 was the first year they used SD to replace the MAF on fbody's... so 89 and lower used MAF
Old Oct 24, 2003 | 08:59 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I replaced my MAF sensor, in my 89 Formula 350 TPI, with one from Autozone. I believe it was around $200. It's been working fine ever since.
Caspar
Jun 19, 2016 11:19 PM
mdtoren
Aug 23, 2015 12:52 PM
redmaroz
Aug 16, 2015 11:40 PM
92purpz28
Aug 11, 2015 02:30 PM
