dual snorkel
Old Oct 22, 2003 | 09:03 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
dual snorkel
Does anyone know if an '80 corvette dual snorkel is the same as, or will work on, our 305 (lg4)?
thanks,
phil
Old Oct 22, 2003 | 10:54 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if its on a 4 barrel should work just fine
Old Oct 22, 2003 | 01:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
SSC had a post about this a few weeks ago. He got one off of a Vette, I'm not sure he said what year. The spacing between the snorkels was different.
Old Oct 22, 2003 | 01:19 PM
five7kid's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=201118
Old Oct 23, 2003 | 12:40 PM
Parrydise7's Avatar
One of the magazines had an article about this. It has to be modified, although the article didn't say how. I don't know why the guy didn't just use the Camaro dual snorkel. Anyway, IROCZDAVE usually has those dual snorkels available. The last time I checked he had one for $100. The ducting is getting hard to find.
That Camaro dual snorkel will bolt right in, although when I installed one on my LG4, I couldn't get the hot air tube to match up because of all the wires and hoses.
Old Oct 23, 2003 | 05:13 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The late '70s, early '80s Corvette dual snorkel air cleaners are almost identical to the L69 ones.
If you still have a Qjet on your engine, it should fit fine. If you have some other (ie. Holley) it probably will, but theres a chance it wont.
91 SrS
Oct 7, 2015 04:32 PM
zman1969
Oct 1, 2015 11:09 AM
