can't find miss
Old Oct 25, 2003 | 11:20 AM
Air21's Avatar
can't find miss
swapped engines between cars, 86' 305 TPI, rebuilt the top end, springs and seals. The engine was smoking a bit before i pulled it.
There is no smoke on idle or anything. I have a miss now that i cannot find. I put on a new cap and rotor. The ignition coil is the original i beleive as well as the dist. The wires are on correctly. And i have tried jumping it teeth with no result. I twist the rotor to at least get it close and still nothing. Seems like a cylinder is not firing at the right time. I have no vacuum leeks.
Old Oct 25, 2003 | 01:24 PM
ede's Avatar
ede
have you actually tried to set the timing with a light? how do you know you don't have a vacuum leak? do you have fire at the end of each plug wire? have you check spark with a spark checker? valves adjusted right?
Old Oct 25, 2003 | 05:26 PM
Air21's Avatar
timming is set to 8* advance. I am going to OHM my wires tomarrow they are pretty new, but just want to check anyway. Valve train is fine.
Old Oct 26, 2003 | 03:48 PM
Air21's Avatar
changed the wires today, some of the miss is gone. But is still missing. It has a searching idle as well. When i put it in gear it bogs down and wants to die.
eightsixseven
Dec 16, 2024 01:50 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mhatfield 14
Oct 24, 2015 07:48 AM
dbrochard
Aug 30, 2015 05:56 PM
Bryan F
Aug 27, 2015 07:28 AM
