thief tried to hotwire my RS-won't start
Old Dec 10, 2000 | 08:43 PM
Raybird86's Avatar
Someone broke into my '89 RS, tried to take off with it, but couldn't- I think because of the computer chip(?) in the key. The piece of plastic above the tilt lever was pried off, and the car won't crank-the key turns almost to the "on" position. Anyone know if I can fix this myself/how much it would cost???
Old Dec 10, 2000 | 09:22 PM
CamaroMike's Avatar
Same thing happened to my bird. Just take it to a steering column place. About 300 bucks to fix.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Dec 10, 2000 | 09:42 PM
mike88RS's Avatar
well, you could go to a column place for $300 or go to a salvage and get a whole column for $75 or less. the vats columns may be more, but its possible. obviously, wiring around the VATS is not a good idea in this situation
Old Dec 11, 2000 | 12:22 AM
Chris Luongo's Avatar
Yes...you will need to get a new steering column or have yours repaired. In the meantime, try tilting the wheel to various positions, and maybe turning your key a bit...you might get it to start so you can drive it.
By the way, I hear that non-tilt cars are slightly harder to steal, so if you're worried about this happening again, maybe get a non-tilt column.
Old Dec 11, 2000 | 12:30 AM
Vader's Avatar
Ray,
Been there. Once the would-be thieves trash the column, you might be pretty much screwed. If the rack gear is broken, you are screwed. GM makes plenty of repair parts for just such an occasion. A replacement column from the bone yard might be cheaper, but the amount of work will be the same if it doesn't have exactly the same options as your column does. Don't sweat the steering wheel, since you can probably install yours on the used column.
There are also a few companies that market a stainless steel band that bolts around the column bowl to deter such morons and posers.
After my roller skate was stolen, I got very sensitive to the frailty of the steering column. If you're not into the stainless band clamp, you could look into something different. I installed a different kind of deterrent on my T/A, and got a pretty good ($18.00) insurance discount for it:
It's pretty tough to drive off with a car with no steering wheel. They could trailer or tow it, but would most likely move on to the next unsuspecting future victim.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
[This message has been edited by Vader (edited December 10, 2000).]
eightsixseven
Dec 16, 2024 01:50 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
