What is the correct lugnut style for IROC wheels?
Old Oct 27, 2003 | 12:40 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
I wasn't sure if I should post this here or in the History board, but:
What is the correct style? Are acorn lugnuts ok? That's what I'm using and they seem to be digging into the wheel. My car has a shake at 55-60+ MPH and I wonder if the lugs have messed up the wheels. Thanks.
Old Oct 27, 2003 | 01:01 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
it should be the acorn style. If you look at your wheels, you can clearly see the tapered seat.
Old Oct 27, 2003 | 01:10 PM
I thought so...but it looks like maybe some stupid tire shop overtightened them or something because the seats aren't pretty.
Thanks!
Old Oct 27, 2003 | 07:12 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
can you post a pic? if the wheel was run loose it will egg shape the hole. you may also just need a wheel balance maybe you lost a weight. if the vibration is only in a small range of mph it sounds like balance. if you feel it in the seat it is the rear wheels if it is in the steering wheel it is the fronts.
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
