Dodge Shadow Question! For a friend!
Old Dec 11, 2000 | 03:13 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
He doesnt know anything about cars. He has a 92-94 dodge shadow 2dr with a 4 banger in it and it wont start.
It turns over very well, but doesnt start. I checked all the spark plugs, and the dist. connectors, they all look ok.
What else could be wrong? How do you check for system codes on those things?
Thanks for the help,
Daniel
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
Old Dec 11, 2000 | 03:45 PM
jrr's Avatar
jrr
I'm not familiar with the Dodge, but the troubleshooting is the same. If it's getting spark, then it must not be getting fuel. I would bet the fuel pump is dead. If the pump was working, but the fuel injector was clogged, it would still run. It would run like S**T but it'd still run.
I'm not sure what kind of tools you may have but flipping through a Haynes or some kind of repair book at the local AutoZone or library would help you troubleshoot a possible fuel pump problem.
An easy way to check for spark is to remove one spark plug, reconnect the plug wire and lay the plug on the block or bare metal place under the hood. Crank the engine and see if the plug is sparking or not. A spark tester would be better but that is one way to check it if you don't have one.
Old Dec 11, 2000 | 03:53 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Give it a good tune-up and check the bloody oil- really, no kidding! And make sure there is spark. My wife's sister has had three and it's either low on oil or the ignition wire cores (carbon) have been taost - looked great, junk inside.. They foul up quickly and the ignition system is anemic. In both these cases it won't start.
"The people always have some champion whom they set over them and nurse into greatness... This and no other is the root from which a tyrant springs; when he first appears he is a protector.
-Plato
Old Dec 11, 2000 | 04:52 PM
mike88RS's Avatar
well, those 2.2/2.5s are notorious for blowing pick up coils. some have one lead, others have two, but either way they are flimsy. the good news is, they are easy as hell to replace. just pull the cap/rotor. its held in by two screws underneath rotor(big plastic disc) unplug the connector and shes out., change that, and plugs, and check the wires if they are the plug ino cap kind
good luck
mike
Old Dec 12, 2000 | 12:03 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Does it crank faster than it should? These things have a timing belt that could have gone. Luckily, it's not an inteference motor (Doesn't bend valves when the belt breaks). The belt is really easy to replace, too. The top part of the timing belt cover is really easy to remove (2 or 3 bolts, I can't remember) and you'll probably know right away if the belt is bad. Make sure the cam turns while cranking the engine.
Check the spark, and if you have it, look to see if fuel is spraying from the injector. If no fuel, listen for the pump to run. The injector could have gone, the computer, many things! Let us know what you find, and maybe we can narrow it down. I have worked on a bunch of these, so I like to think I can help you out!
Good luck!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
chazman
Aug 28, 2018 03:25 PM
mustangman65_79
Aug 31, 2015 12:08 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
