prop valve, disc or drum?
Old Oct 29, 2003 | 09:08 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
I have a prop valve that i hope is for disc. There are some numbers on it. They are NC 34 KH 18 9. not sure what they mean,... i believe it came off of a 18006814 master. anybody know if it is disc or drum? thanks a lot.
Old Oct 30, 2003 | 05:10 AM
ede's Avatar
ede
flat sided machined aluminum is the later one, for rear disk or drum
Old Oct 30, 2003 | 09:06 AM
Car: 1987 GTA
Ok, I'm confused. I have a 87 GTA. I switched from drum to disc a long time ago. I heard that my master had to be changed.. SO i bought a prop and master from a 89 4 Wheel disc car, or so I was told. I just want to verify that it was the right part. Without close examination, they kind of look the same. Also, is there a way to cnage the black prop valve mounting bracket? It appears to be pressed onto the bottom of the prop. THe new one is rusty and mine is perfect. I'd like to change it. Any ideas? thanks
Old Nov 3, 2003 | 09:08 AM
Car: 1987 GTA
anyone?
Hotrodboba400
Dec 10, 2019 07:07 PM
devilschariot
Feb 25, 2016 03:08 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
