knock knock......whats there?
Old Oct 30, 2003 | 06:29 PM
ponykiller's Avatar
Car: 89 camaro w/t-tops
Engine: lo3
The lo3's driving me nuts!!!!!
I've developed a knock.But its only if I accelerate while driving.If I'm idle,its OK.I can rev...its OK.But I drive down the road and clickclickclickclickclickclickclickclickclickclick.
My first thought is my push rods and/or rockers, since I did recam it a month or so ago.But wouldnt that be constant and not only in acceleration?I also put in 92 octane gas.It still knocks.Changed plugs and wires.Still knocks.
Its too loud to be injectors or exhaust.
Any ideas?
Old Oct 30, 2003 | 07:54 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I WAS going to say def. sounds like bad plugwires, but you said you changed those already...
Have you checked your timing? Maybe it's way up high. I believe retarded timing will have similar effects too....
Or leaning out is a possibility as well. Check your plugs and fuel pressure...
Old Oct 30, 2003 | 08:01 PM
ponykiller's Avatar
Engine: lo3
Yeah,I changed the plugs and wires Monday.
I was thinking it may be lean.....I actually have one of the electricians making me a winaldl cable.Maybe I'll give it a spin this weekend.
Thanx for responding.
Old Oct 30, 2003 | 09:15 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
Wouldn't you be looking for something in the driveline instead of the engine since you can rev it up without hearing it?
Old Oct 31, 2003 | 05:22 AM
ponykiller's Avatar
Engine: lo3
Never thought of that......
It sounds like its from the engine though.
Old Oct 31, 2003 | 09:36 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
So does a torque converter bolt comming out when you accelerate in gear.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
