305 pistons interchangable?
Old Dec 11, 2000 | 06:16 PM
Canam's Avatar
I have a set of pistons from a 1988 305 that I would like to put into a 1985 lg4. Will these be compatible? Thanks.
Old Dec 11, 2000 | 07:42 PM
ede's Avatar
ede
as long as they're both 305's i don't think you'll have a problem. you can have your parts store check part numbers to make sure.
ICON Motorsports
1st & 3rd
Old Dec 11, 2000 | 08:33 PM
Canam's Avatar
ede
I had checked with a parts dealer and that's the confusing part. The ring grooves,valve reliefs, and dished top are all the same. Yet they are listed as replacement for 1987-92 305.
Old Dec 11, 2000 | 08:51 PM
ede's Avatar
ede
87 is when gm went to the roller cams and one piece main seals, but i don't see where that would matter with the pistons.
ICON Motorsports
1st & 3rd
Old Dec 11, 2000 | 09:19 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Apart from ede's post above, make sure they are the same bore size (ie: 3.736", +.020", +.030" etc ...).
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Chevy Info --> MadMike's
Old Dec 11, 2000 | 09:30 PM
Guest
Guest
Posts: n/a
The rear main changed in 86, a technicality, but anyway...
Parts books are far from 'THE' source on what is interchangeable. You say the dish is the same, so I am assuming it had the cc listed or something like that. The compression height could be slightly different, but thats not going to create a problem on an LG4 unless it has some sort of radical cam that the valve clearance should be checked on anyway. My guess is its either a minor change that doesnt matter, or they are actually the same and the parts book lists 2 different numbers for the same part... wouldnt be the first time.
Old Dec 13, 2000 | 09:45 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Note that if they are dished, they are LG4 pistons. If they are flat-top with four reliefs, they are either L69 high-output pistons, or TPI 305 pistons, both of which were 9.5:1 compression engines. These cast pistons, when coupled with a 58cc chamber on the head, and a .015" steel head gasket, made 9.5:1 compression. Hence, their higher output potential.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
angel2794
Sep 8, 2015 06:22 PM
TheTraut88
Sep 7, 2015 05:22 PM
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
masonta
Sep 1, 2015 06:40 PM
