Please HELP with ebrake..........!!!!!!!!!
Old Dec 15, 2000 | 08:07 PM
irocbsa's Avatar
I am in the process right now of doing a drum rear swap and have gotten everything disconnected except the ebrake cable. It says nothing about it in the Haynes manual. The haynes manual also skipped over a few important steps in removing the rear end, such as remove the track bar. I'm really losing faith in the Haynes..........
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat,
Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
Old Dec 15, 2000 | 08:56 PM
irocbsa's Avatar
nevermind..........got it.
