Help Please!!!!
Old Nov 3, 2003 | 05:14 PM
Teenfixing88RS's Avatar
Car: 1988 Camaro RS
Help Please!!!!
My car began to make a "rattling" noise about a week ago and i was wondering if this has happen to anyone else and how to fix it..... If im not mistaking its comming frm the engine and it kcik up when i accelerate and im starting to kreep out ... please help with ne info you guys /gals might have..
oh yeah i have a 1988 camaro rs 2.8L 5 speed thanks a bunch
Old Nov 3, 2003 | 05:49 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
worst case u have a spun bearing... not so bad u have a collasped lifter.. easy case your vavles studs backed off a lil n they are rattling.. does it happen all the time or just when u start it up cold, just when u rev it up?
Old Nov 3, 2003 | 06:33 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Transmission: 700 R4
Axle/Gears: 370 BW
Not nearly enough information for us to help at this point.
Rattling = Not to many internal components. Knocks and Taps do.
Does it do in in neutral and increase with RPM or just when car is moving?
Use a screwdriver or something like it and place it to different engine components and put your ear to the plastic side and listen to hear if the sound is internal, move do different locations on non moving engine parts to determine the closest point to the noise.
If you hear tapping or knocking from inside, ground your plug wires using a grounded probe and again listen for the noise to go away.
There are some things to start with. Gather a little more information and post back with results for further assistance.
Old Nov 4, 2003 | 12:29 AM
Car: 1988 Camaro RS
ok... its beginning to doit all the time it does it after ive been running for a while.. i can feel it in the acceleration pedal... it starts when i hit about 3000 RPM in second gear and every other gear after.... it began to do that about a week ago... lets see what else can i add...also i think it does it when my car is going up hill...... (could it be the rims i have on it? 18" irocz)
