86 lg4 engine accesories work with a 327?
Subscribe
Dec 15, 2000 | 01:29 PM
just need to know if the powersteering and alternator and ac brackets and stuff will hook up to the block, everything should be the same bolt holes right?
Steve
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat.
Current Plans: 342 posi disk 10 bolt rear, coming in late december, in february or april, level 10 tranny, new convertor, june- lowering springs, possibly torq thrust II chrome wheels, and new 245 stickies up front, 255's out back, the cowl hood will be installed and painted, new cold air induction, mid summer, hoping to have enough money to scrape together a 350 hp 350... gonna keep things fairly mild.
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Reply 0
Dec 15, 2000 | 01:41 PM
The block is identical externally. The only differences I can think of has to do with the clutch pivot ball boss, and maybe needing a spin-on oil filter adapter.
The heads, however, may not be identical. Most 327s came with heads that do not have the accessory bolt holes in the ends, which is impossible to duplicate, the best you can do is (insert your choice of racial epithet here)-rig it; and all 327 heads have a symmetrical exhaust manifold bolt pattern, so the late-model manifolds with the one bolt stuck way out in the ozone (far back pass side) cannot have that one bolt installed. So you need to be sure what heads you are planning to run on it.
Reply 0
Dec 15, 2000 | 04:52 PM
so does that mean, if i went out and bought some dart iron eagle heads, i would have basically a setup that i could put my edlebrock headers on, AND my accesories?
Steve
EDIT: i am assuming that the block is fairly stock, and stock compression ratio. what size chambers am i lookin for 64cc or 72cc? i am assuming that it is runnin 9-9.5 compression ratio... also what intake runner size? 180? or 200cc?
[This message has been edited by fb305svs (edited December 15, 2000).]
Reply 0
Dec 15, 2000 | 04:55 PM
the dart heads should have all the bolt holes in all the right places.
ICON Motorsports
1st & 3rd
Reply 0
Dec 15, 2000 | 06:02 PM
take another look at my edit ede and rb- luv to know what ya guys think...
steve
Reply 0
Dec 16, 2000 | 07:57 AM
Flat-tops are common in 327s. With 64cc heads, it will be in the 9.6:1 neighborhood with 64cc heads. That's what I would suggest, or perhaps as low as 60 or 62cc which would put the CR just at or above 10:1.
Without knowing the specifics of how you are intending to build the motor, I can't be certain about the ideal runner volume; but 180cc runners on a 327 should give similar RPM characteristics to 190 or 195 on a 350. The 327 will have a tendency to have less torque at lower RPM than a 350 since it is less inches; but since its stroke is so short compared to its bore, its peak torque and therefore HP will be at a higher RPM than an otherwise identical 350.
Reply 0
Subscribe
