Advancing Timing
Old Dec 15, 2000 | 08:39 PM
83Z28's Avatar
Advancing Timing
I've never done this before, so I would appreciate any help. I have a couple of questions. First, where are the timing marks located? (lg4) I've looked, but I can't see them. Second, how do I loosen the distributor so I can turn it, and which way do I turn it to advance the timing? Thanks for the help.
Adam
Old Dec 15, 2000 | 09:49 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Ok let's see here....the timing marks are on the balancer and you compare them to the timing tab on the timing cover. There is either one or two bolts holding the distributor in place. You have to loosen then which is usually a pain. (they make special distributor hold down wrenches or you can use a crow's foot.) Then to advance the timing the distributor gets turned counterclockwise.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
***** Flyby: (n) When you let off the throttle after beating a ***** Racer by a few car lengths and he then blows by you in an attempt to convince you he really won the race.
Old Dec 16, 2000 | 02:23 PM
83Z28's Avatar
Thanks.
Amillionoh7
May 24, 2020 08:01 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
