AC delete serpentine belt
Old Nov 4, 2003 | 08:12 PM
REDRAGTOPRS's Avatar
I recently removed my Smog pump on my 89' Vin E 5.0l TBI. The bearing in my AC compressor is gone, and until I replace it, I was wanting to reroute the serpentine belt so that it does not go around the AC compressor pulley. Has anybody done this conversion, or is there a shorter belt that was installed on third gens that did not have factory AC? If so, would this belt be too long, since my smog pump is removed?
Old Nov 5, 2003 | 01:38 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I do believe I had a 86.5'' belt on mine. I ran the belt in the stock routing but ran it overtop of the tensioner. I had it like that for the better part of 2 years with 0 problems.
Best thing to do is get a string and route it the way the belt would go...then measure it. Mid as well buy the 3 closest sizes to your measurements so you dont have to run back and forth to the parts store.
If you remove the pass side bracket completely you can run a 50'' belt like I did. Ill try to get a picture so I can show you what I did.,
Old Nov 5, 2003 | 07:23 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Go to this thread
jrdturbo
Mar 31, 2016 02:58 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
