The 383 is alive
Old Nov 4, 2003 | 09:23 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
The 383 is alive
Little clip of it from today.... Should have a Y-pipe later this week.
383 Video clip
Old Nov 4, 2003 | 10:51 PM
LnealZ28's Avatar
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
That thing sounds evil, man. That ZZX is a killer stick. I have just ordered a TPIS 700-701 mech. roller stick for my Mini Ram 383 project which should be here by Friday. I still have quite a way to go before mine's finished, but your sound clip may just get me through until it is!
Old Nov 4, 2003 | 11:17 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Motor sounds sweet...
Can't wait till I have the cash to build my big block next summer. It's getting a nice solid roller 246 dur cam...
Old Nov 5, 2003 | 12:02 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Yummy
Congrats!
-Schultzy
Old Nov 5, 2003 | 12:20 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
On the 383 you have a miniram right?? is that just the intake or did u buy the whole setup with a computer and all??
Old Nov 5, 2003 | 01:29 AM
Matt87GTA's Avatar
Thanks for the compliments guys.... I can't wait to get the Y-pipe fabbed up later this week so I can re-enable closed loop and put some tuning on this thing. With the O2 so close to the end of the collector of the header it thinks it is pretty lean and starts pouring the fuel on pretty voraciously if I let it have closed loop.... The tune is pretty rough right now so I haven't really driven it at all.... Just did the initial 1/2 hour run and first oil change. Plus it is pretty much too loud for all but the bare minimum of driving around.
Yes that is a Miniram on the 383. I polished the fuel rails a bit (nothing really serious but they look OK) and painted it with bright red engine paint (should have powdercoated - I know, but paint is cheap). I bought the Miniram off of a TGO user through the classified boards here. It is a Miniram I and came with the fuel rails and regulator. I built my own 6AN lines that come off the hard lines and feed the Miniram. I had to cut off and flare the existing hard lines with 6AN and 4AN (return side, adapted to 6AN for the flex line) tubing nut fittings to make it all work.... That was a lot of fun .
Old Nov 5, 2003 | 01:37 AM
Car: 89 Formula
Engine: Carbed 5.7
U have the stock computer?? I wanted to go fuel injection but I didn;t think i coudl run a lopey cam with it. If i get the mini ram and use all the stock wiring and computer and stuff from the tpi what woudl I have to do to get it to run right?? Do I just take it to sumplace and have them burn me a chip or sumthing?
Old Nov 5, 2003 | 05:48 PM
Matt87GTA's Avatar
There is basically no limit to the size cam you can run with EFI if you have the proper equipment.
I have a speed density system like the one used in 91-92 thirdgens running my engine but there are MAF cars with plenty radical engines in them as well. It can be done.
I would suggest reading up on the basics of tuning PROMs on the DIY PROM board on this site if you would like to tune yoru own car or just call up an aftermarket tuner such as TPIS or Ed Wright and find out from them what a PROM runs and what their limitations are on what kind of setup you can run if you aren't interested in/able to do your own tuning.
Old Nov 5, 2003 | 06:26 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
HOLY %@#$@ that thing sounds evil!!
You need to get more videos of that thing. Awesome job. Engine looks killer :hail:
Old Nov 5, 2003 | 07:30 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Sounds awesome, good luck with the tuning!
Old Nov 5, 2003 | 09:53 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
yeah for sure, shes a beauty...
now lets see her lay a lil bit of rubber
Old Nov 5, 2003 | 10:01 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Where did you get those valve covers?? Me like!
Old Nov 6, 2003 | 01:31 AM
Matt87GTA's Avatar
Thanks again folks
Those valvecovers are the cheapy tall Summit brand polished AL ones.... Like $60 or so from Summit. But they are perimeter bolt pattern as that is what my Brodix heads are.
Burnin rubber will be a while.... Well at least a few weeks as I need to get the Y-pipe fabbed up (heading in tomorrow to start that at a local shop), tune it, and break it in the rest of the way...
Old Nov 10, 2003 | 09:09 PM
Z06Z28's Avatar
It sounds even better in person.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
