Flow values for L69 Heads
Old Dec 16, 2000 | 10:26 AM
bigsweed's Avatar
Anyone know how much the stock L69 heads from an -84 Trans Am HO flows?
/bigsweed
Old Dec 16, 2000 | 03:06 PM
Vader's Avatar
BSwede,
Welcome aboard! And Season's Greetings to the land. I live in a town that was originally a Swedish/American settlement, so there is still a lot of the scandinavian influence in the area. There are probably more Volvos per capita around here than in most of the rest of the world. Lots of Norskes, too!
If you have a casting number (located in the rocker area under the cover) you can check the specifications at www.Mortec.com.
As I recall, the older 305 heads are nothing to get excited over, but can be ported with some success. I'll guess that the stock heads would flow less than 180 SCFM peak, even with the larger 1.84 valves.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 16, 2000 | 09:11 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
The L69 heads are identical to the LG4 heads for 1984. 1.84 intake, 1.50 exhaust. You'll find that the '84 heads are better suited for porting than the newer heads (centerbolt) due to the open area around the intake valve. It's less shrouded around the valve, and will probably allow you to install an oversize 1.94 intake valve. However, dont install the big valve unless you commit to doing some extensive porting to the intake tract to take advantage of the bigger valve.
Chuck84TA
Jul 15, 2016 09:05 PM
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
