Rocker Arm Poly Locks??
Old Dec 16, 2000 | 07:20 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
Can you use Poly Locks on stamped steel rocker arms? I heard they do a better job of staying adjusted.
1988 GTA 5.7L Auto
355 ci. block, SLP Cold Air Intake w/ K&N, fully modified MAF Sensor, TPIS 52mm Throttle Body w/Air Foil, Fully Ported and Polished Plenum, Nikel-plated Ported SLP Siamesed Runners, Ported TPIS Big Mouth Intake Manifold, stock heads w/ 1.52 Comp Cams Self-aligning Roller Rockers, TPIS ZZ-9 Roller Camshaft, TPIS Valve Springs, Cloyes True Double Roller Timing Chain, TPIS Adjustable Fuel Pressure Regulator, Balanced Bosch 22 lb/hr Fuel Injectors, MSD 6AL, Taylor 10mm Wires, Bosch Platinum +4 Spark Plugs, MSD Blaster Coil, March Underdrive Pulleys, 6 3/4" Vibratech Streetdamper, TPIS Level 3 PROM, 160 T-stat, Low Temp. Fan Switch, Stock Distributor w/ Bronze Gear, SLP 1 3/4" Headers, Random Technologies High Flow Cat., Adjustable Borla Cat Back Exhaust, Level 10 PTS-3 700R4 Trans, B&M Holeshot 2400 Stall Converter, B&M Trans Cooler, TCI Aluminum Finned Trans Pan, 3" Balanced Aluminum Driveshaft, 3.73 Richmond Gears, Auburn Pro-Series Differential, LPE Aluminum Differential Cover w/ Main Cap Preloads, BF Goodrich Drag Radials, Hotchkis Lower Control Arms, Hotchkis Panhard Rod, Bilstein Heavy Duty Shocks and Struts, 1LE Springs, Energy Suspension Polyeurethane Bushings, Global West Tubular Subframe Connectors, Global West Steering Box Brace, HP Motorsports 3 Point Strut Tower Brace
"Why ride a stang when birds can fly?"
Old Dec 16, 2000 | 07:23 PM
ede's Avatar
ede
sure you can.
ICON Motorsports
1st & 3rd
Old Dec 16, 2000 | 07:24 PM
where can I get them??
1988 GTA 5.7L Auto
Old Dec 17, 2000 | 10:33 AM
Vader's Avatar
Joseph,
Any good hardware store should have a full selection of Nylock nuts, plated and plain steel. I said hardware store, not home centers like Home Depot and Lowe's. Those places are to hardware stores like AutoZone and Pep Boys are to auto parts houses. Trying to find good Nylocks at Lowe's would be like asking to get a three-angle valve grind at AutoZone.
Oh, yeah. Get plain steel full pattern nuts instead of plated if you can. 3/8-24 full Nylocks go for about $14.00 per humdred end user price.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
