Fuel Pump Relay and Fuse
Old Nov 5, 2003 | 08:50 PM
HAIRYGARY's Avatar
Car: 1992 Camaro Z28 Convertible
Can anyone tell me where to find the fuel pump relay and fuel pump fuse on my 1992 camaro Z28 with 305 TPI? My car died and since the fuel was pretty low I assumed I had run out of gas. I put a couple gallons in and expected the car to start right up, not. It started, but idled rough and finally died. I thought I may have sucked gunk from the bottom of the tank and plugged the fuel filter, so I changed that, nothing. The car turns over and I have spark, but it will not start. The fuel pump is inside the gas tank and repairs will cost several hundred dollars if the pump is bad. I am hoping I have a bad fuse or relay but cannot find either one. Help!!!
Old Nov 5, 2003 | 09:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Fuel pump fuse is in the fuse block under the dash at drivers left knee. Not entirely sure about the location of the fuel pump relay, but I believe that it is located in the engine compartment on the driver side firewall. Rectangular unit with a rectangular connector with five wires.
The Trickster!!!!!!!!!
Old Nov 5, 2003 | 10:10 PM
Vader's Avatar
Gary,
Welcome Aboard!
Unless your IROC is an odd one, the fuel pump fuse should be located along the right inner fender rail:
The relay is likely mounted to the left side of the firewall:
Old Nov 5, 2003 | 10:31 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if you want to test the pump directly, assuming it isnt shorted out internally and blowing fuses, you can hook a +12V sorce up to the grey lead in the connector for the FP relay. This will supply the pump directly with power.
EDIT: The one that leads to the fuel pump is the furthest most wire from the red one that supplies the relay with +12 volts.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
