question about 86 LB9 heasds and the LO5
Old Nov 7, 2003 | 08:56 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I'm rebuilding the LO5 for my 84, and need to find a set of heads, so far I haven't found any good 1.94s, but I figured the LB9 heads would work for now
The LO5 motor is a flat tappet motor, I already have the cam and intake (non center bolt) I've read you have to change somethings on the heads to get them to work? is this true? even on a flat tappet engine?
Vic
Old Nov 7, 2003 | 01:06 PM
iroc22's Avatar
What do you mean by changin things?
They will bolt right on, the only problem I can think of is the 58cc chambers will yield a higher compression ratio on a 350. Make sure your springs match the cam.
Old Nov 7, 2003 | 01:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can improve the heads, but you don't have to do anything to make them work.
Improvements would be 1.94" intake valves (requires machine shop work), valve springs as previously mentioned, and screw-in or pinned rocker studs. Some basic porting, especially bowl area work, would substantially improve them. A full porting job following Standard Abrasives Do-It-Yourself Guidelines would be the cat's meow.
If you're worried about high compression, you can unshroud the valves a little while doing the porting and increase chamber volume a little. Most likely, though, the LO5 has dished pistons, so the smaller chambers would actually be beneficial.
BTW, those heads have the slotted pushrod holes, so you don't want to use self-aligning rockers (which I believe an LO5 would have). And, if going from roller lifters to flat-tappet, you'll need different pushrods.
Old Nov 7, 2003 | 03:28 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
the "things" were the rockers and push rods, and something about drilling the guides out
Old Nov 7, 2003 | 11:41 PM
five7kid's Avatar
I'm afraid I wasn't fully with it in my last reply.
LB9's came in different styles through the years. Which castings are these heads?
Pushrod requirement will be dictated by the type of lifters. If flat tappet, you need the earlier longer length.
The way the rockers are guided is dictated by the type of pushrod holes. If earlier style with slotted, you need non-self-aligning rockers. If later with larger rounded holes, then self-aligning. You can drill out the slotted type to use self-aligning rockers. Perhaps that's what whoever was telling you about drilling meant.
They had some wierd mixes out there in the early LB9 days, so you need to know what you've got.
gta90
Sep 15, 2015 04:00 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
kyleb24
Aug 15, 2015 08:24 AM
