Car dies when put in gear!
Old Nov 7, 2003 | 08:00 PM
LT1Formula's Avatar
Ok, I have a 91 GTA that I jsut put a heads and cam deal on it and finally got it put back together yesterday. After tweaking the fuel pressure and the timing I got it to run good. Only problem is when you shift into gear(it's an auto) it jerks and immeadiatly dies. Not sure what is causing it but I'm stumped! Any helpe would be great!
Thanks Jake
Old Nov 7, 2003 | 11:43 PM
85TransAm406's Avatar
Car: 1985 Trans Am
Sometimes the TCC doesn't disengage properly, causing a bigger load on the engine (like letting out the clutch at idle). could be one of a few things, but with mine the TCC solenoid was stuck open.
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
killer777
Aug 8, 2015 02:47 PM
