BELT HELP
Old Dec 18, 2000 | 01:19 AM
CAMARO-90-RS's Avatar
BELT HELP
I HAVE A 1990 CAMARO RS 3.1L . I SEEM TO HAVE A PROBLEM WITH THE BELT ON THE ENGINE.
THE BELT IS KINDA LOOSE . HOW WOULD I GO ABOUT FIXING IT
Old Dec 18, 2000 | 01:22 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Replace the tensioner. It is fairly common for these to fail. I've replaced quite a few of them! I think they run around $50-60, but I'm not sure, never had to buy one, always been on customer cars.
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Dec 18, 2000 | 01:27 AM
Vader's Avatar
90RS,
Or, if you're a cheap SOB like me, you can press in a new $6.00 bearing and 10¢ roll pin for the spring anchor and drive it for another eleventy-seven thousand miles.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
