Car wants to die when put in gear
Old Nov 7, 2003 | 08:04 PM
LT1Formula's Avatar
Ok, I have a 91 GTA that I jsut put a heads and cam deal on it and finally got it put back together yesterday. After tweaking the fuel pressure and the timing I got it to run good. Only problem is when you shift into gear(it's an auto) it jerks and immeadiatly dies. Not sure what is causing it but I'm stumped! Any helpe would be great!
Thanks Jake
Old Nov 7, 2003 | 08:22 PM
DMSBRASILEIRO's Avatar
Car: 85 iroc-z
Engine: 350-headers,cam,3"catback
gas i know it sound stupid but my car did the same thing it was because i was low on gas it would rev fine in park and neutral but the second i put it in drive it would still
Old Nov 7, 2003 | 10:19 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
is it cold? i know mine when its cold or has set for a long time,i cant put it in gear til it warms up cuz itll die....sounds strange but just a thought
Old Nov 7, 2003 | 10:21 PM
0cP's Avatar
0cP
You either have a vacume leak or not enough vacume from that new cam. But you might be able to get away with turning up the idle air speed and stuff you just got to try diffrent things.
Old Nov 7, 2003 | 11:18 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Sounds like you need to adjust your timing again.
Old Nov 8, 2003 | 12:46 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I have a T5 in my car, and a carb, but mine is the same way. Mine can't be driven untill its got a chance to warm up to about 45-50*C.
After that, its perfectly fine.
MustangBeater20
Oct 29, 2022 09:20 PM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
