I just replaced the water pump, radiator, hearders and did a tune up and the car wont start with out starting fluid an the it will not stay runing after it is started unless you rev it to kept running.
pks help me.
pks help me.
have you tried trouble shooting? plug wires on right and in order? any other wires not connected? how about vacuum lines?
I second the vacuum check. Even if one line is off the fitting or broken or dry rotting (yuck!) your engine may not start at all or will not keep running without a foot on the gas.
