is this worth it
Car: 91 Z/28 convertible
is this worth it
http://store.summitracing.com/defaul...02015&x=16&y=9
click where it says CEI-102015
what is every ones opinions on this
and our those under drive pulleys worth the money or not?
and will this fit my car its a 91 z convertible http://store.summitracing.com/defaul...3120&x=18&y=12
and 1 more question guys what would i have to do to get these to fit http://store.summitracing.com/defaul...&part=cee-3046
in the summit mag it says you have to move your springs inboard you have to modify or fabricate your frame rails
thanks for all the help guys
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Throttle enhancer IMO, is not worth it... think "hypertech". Subframe connectors add some nice rigidity to your vehicle. Bolt in or weld in will work. If you are experienced and know what you're doing, then get the weld in and tack 'em on. If not, then get the bolt in and enjoy the ease of instillation, hope that helps.
skinny z
Oct 5, 2015 06:23 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
