Just a quick easy question
Old Nov 9, 2003 | 05:44 PM
bes217's Avatar
I was just making sure that I have this correct. 350 and 400 heads are interchangable correct? If so, then I could use vortec heads on a 400? Would I make more power doing some port work on the vortecs or would I make more power doing port work on the stock 400 heads? I don't want to go too wild since this will be a street engine. So some minor cleaning up and porting work for better flow. Also, I have some GM pink rods that I wanted to use, could I use them in a 400 buildup with a stock 400 crank? Thanks in advance for your help.
Old Nov 9, 2003 | 06:10 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Just a quick easy question
If you're going to get custom pistons then yes you can use those rods. For the heads just make sure you match up all water passages from the block to the heads including the steam holes.
Don't forget to make the head gasket match as well. Normally 400 gaskets have the steam holes.
ede's Avatar
ede
all SBC heads will bolt up to any SBC block. there are differances in the intake bolt patterns and steam holes for a 400.
Jorlain
Aug 24, 2022 05:11 PM
Dkelz313
Apr 7, 2016 10:38 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
TheJoeY88
Aug 13, 2015 06:51 PM
