Help my gta runs horrible!
Old Nov 10, 2003 | 07:52 PM
thenick's Avatar
I need help!!!!!
On sat. afternoon on my way home my 87 gta started bucking popping sputtering and generally running like crap and not lettin me get over 30 miles per hour.I couldent give it any gas or it would lose all power and stall. I got home and the check engine light came on so I jumped the ALDL and got a code 44 o2 lean.
I got a new o2 sensor today and the problem is still there.
Help I need this car to get to work tomorrow!!!!!
87 gta 350 tpi auto recent plugs cap rotor maf and now o2
also I did fill it up at a gas station I dont usually use
Old Nov 10, 2003 | 08:53 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
change your fuel filter, if thats not it perhaps your fuel pump took a crap on you...
or even maybe theres water in the fuel...
Old Nov 10, 2003 | 08:58 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Had a similar problem when I swapped a 350 in my 86 Z-28. It turned out to be the cap and rotor. Also check all your plug wires.
Old Nov 11, 2003 | 11:50 AM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
I had that problem on my caddy
I changed the distributor, the wires, plugs...still no good
It was my fule pump.....so give it a check I tested mine and was only getting 6 psi!..that should fix the problem...while your at it get a hi-po one what the hell
Hope this helps man
AJ
Old Nov 11, 2003 | 01:57 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Do a tune up. I have found on both my old 2nd and 3rd gen that they eay ign parts like candy. Even if it is not even time or close for a good full tune up, it fixes everything.
Both times I spent days, wekks and mlotsof money chasing codes and crap and all I needed to do was a good tune up, even thought it wasnt done that long ago.
Old Nov 16, 2003 | 08:24 PM
thenick's Avatar
That seems to be a good start.
But doe any one else have any ideas about my problem?
Old Nov 16, 2003 | 08:43 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
anything could happen. What all have you checked and ruled out???
Matt
bryan623
Mar 22, 2021 06:43 PM
lee01
Apr 9, 2016 01:56 PM
The_Phoenix
Feb 4, 2016 07:10 AM
gta90
Sep 15, 2015 04:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
