ignition problem?
Old Nov 11, 2003 | 09:53 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
ignition problem?
hey guys, got a little problem here. when i try to take off with my car it shakes and it sounds like the exhaust pops a little bit.its almost like when you take off with a manual car and let the clutch out too quickly and it shakes and sputters. at idle the car sounds a little off, but i doesnt miss. however, when i take off it sounds like its missing when its shaking, and the problem is the worst from 1500-3500 rpm. my friend suggested a bad ignition control module. any ideas?
thanks,
dave
Old Nov 12, 2003 | 08:34 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Dave,
Sounds like it could be a timing problem. I would check that before you buy anything.
FYI... I replaced my ignition control module about a week ago and it costs about $35 at Autozone.
Good luck!
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
